Ok, so more likely than not, all of these wiped cam lobe problems arise when we change out the original cam, lifters, etc. The reason Im asking is because I have another low mileage motor I will be putting in my car, and was debating whether or not to change out the cam, springs, etc., but I guess I will not touch them. I plan on just using the car as daily driven but will be running mid 11's occasionally....
By the way, would replacing the springs on an original motor have anything to do with wiping out a lifter? The reason I ask is because on my last stock motor, I had my valve springs replaced (the ones that Kirban's sells), and after a while, the lifter got screwed up, and the pushrod got out of place and screwed up my motor (When I popped the valve cover open after this happened, everything was in place, just the pushrod got out of position due to the screwed up lifter)..this is course happened when I took the car to 150
