Well today I finally buttoned everything up and took the car out for a ride. The transmission has a new pump and Precision's tube kit installed for the Vigilante converter. While the trans was out I put in a new aluminum radiator.
I went out and the trans was stupid sloppy. Slipping in every gear and not shifting right. I had adjusted the TV cable the commonly accepted way but the cable is used and might be stretched. I had to move it 10 or 12 notches back toward the firewall until I got real, solid shifts and no slippage at WOT. Then I noticed the puddle under the car in the driveway - leaking tranny fluid at the new radiator. Now of all of the possible connections that can be leaking: at the trans, the splice I put in just before the trans, the trans cooler, the unions behind the radiator or those impossible-to-get-at cooler fittings on the front of the radiator, guess where mine is leaking? Yes, the impossible-to-get-at fittings - the one on the bottom. I need to take the radiator back out.
Also, the car has gotten very loud. Turns out my Torque-Tech "Y" pipe is split at the "Y" just behind the 'cat'. Even though it's louder and even though I prefer the look of duals, I think I'm going to go with a SS single shot. The duals are heavy and the 3" pipe and mufflers are a lot to jam under there.
At least the lock up problem (the reason for pulling the trans) is fixed. Boy is it fixed. Lock-up is stupid hard and doesn't slip at WOT.
So, I got to cruise around a little bit today. Got a complement from a guy at Lowes and smiles, honks and waves from random motorists. All that makes it a little easier to start draining the antifreeze out of it again......
Jim
