WVhillbilly
- Apr 22, 2012
ok what about that tar looking stuff on the connectors?
SignUp Now!I have both, but your gonna want one inside so you can monitor it and confirm that fp increases with boostok will do, as far as the fuel pressure gauge do i need one inside or do yall just get the one that mounts on the fuel rail?
I have a gauge mounted on the back edge of the hood. You need to view the gauge at WOT. We need to know what the pressure is at idle with the vacuum line removed and WOT with the line connected.ok will do, as far as the fuel pressure gauge do i need one inside or do yall just get the one that mounts on the fuel rail?
You never want to bring fuel into the cockpit. You don't want to drill holes in your hood and I understand why. You can use any pressure 0-100 lbs gauge and some rubber hose to test your fuel pressure. A gauge that measures pressure up to 60 lbs would work.Remove the schrader valve from your fuel rail. Clamp a rubber hose to the end of the fuel rail. Clamp the other end of the hose to a gauge and tape it to the hood or windshield in such a way that allows you to view it. Floor it. I think double sided spongy tape and silicone would be an effective way to mount that gauge. I like having the gauge in front of me all the time because fuel pressure is so critical to these cars. Here are two ideas. I'm sure you can figure something out.ive been looking everywhere trying to figure out how to do that setup without drilling holes or such because the gauges im wanting says must be mounted outside. now im wondering if anybody has mounted one of the mechanical gauges inside with no gas fumes etc,i know its really dangerous if a person was to crash or fitting come loose or something![]()
It runs strong-no issues with that, just wanted to beef it up some. some of you guys have awesome car's and may have done something different if given the opportunity to do over. I'm trying to put together a plan to follow to maybe be able to run in the 12 second range.
Valvoline VR1 is good oil with a lot of zinc. Using conventional oil with STP is a step in the right direction,but it still won't have enough zinc in it. Here is another oil that I and many others use. It is a blend of conventional and synthetic oils and has a lot of zinc.Do not use synthetic oil. Use a conventional oil and add STP oil treatment for older engines.
