hi, i have a holden commodore (australia) which has the buick type 3.8 ltr v6 engine , and would like some suggestions as to what turbo i should use ?
specs are :
heavily ported cylinder heads , stock valves ( no flow numbers....)
2mm copper head gaskets
microtech lt8 aftermarket ecu
ported intake
70 mm throttle body.
220@ 50 thou cam
85 lb injectors
buick turbo pistons and rods ( mallory metal added to crank , due to heavier weight of rod assembly)
all ballanced
intercooler with 3 inch pipe
single 3 inch flow thru exhaust
3.45 gears
2500 high stall.
4l60 modified trans.
some turbo thats easily obtainable and kinda cheapish , preferably !!!
thanks, mark k
specs are :
ported intake
220@ 50 thou cam
85 lb injectors
all ballanced
3.45 gears
2500 high stall.
thanks, mark k
