What upper & lower control arms are best?
49-blues
I'm going to be installing LS-1front brakes with C5 ZO6 calipers, moog drop springs which I ll probably change out to coil overs later- what upper & lower controls would work best with this combo? Best bang for the buck?
I like the speedway motors uppers, and spohn lowers. Probably can spend less then $500 for both, a little more if you go with chromoly.
I like the package deals. Reason being 1. it's easier to just buy a package and 2. it should be designed to work together. That way if you have an issue the manufacture can't say something like, "well, it was never designed to work in conjunction with someone else's part..."
Quite a few companies offer packages for our cars now. Find one thats in your budget and be cognizant of your downpipe to upper A arm clearance.
