SignUp Now!. If you can come up with an "adjustable" design for all bore sizes and strokes at a reasonable price (less than the $950.00 including pins and rings and coating that JE gets!) it would be a big help.
Not with an infinitely adjustable bore and CH.
It's not possible to make a '9:1 piston' as the piston maker has no way of knowing what head gasket, combustion chamber cc's, or deck height they're going in.
Doesn't Wirsco make a 9-1 piston for the 3.8 already?
I get that part there are many variables that affect the final ratio I just thought they had a higher compression piston available.
Here is the Wiesco part number I had saved for future reference PT120A2 I have a NA 109 I have plans forI would be just as inclined to support your endeavors when the time comes if it means better parts for our cars. Picked up an oil pump that had been moded to your specs works like a dream.
One of the first things I do when I open a box of slugs is to squeeze the ring lands and run my thumb and finger all the way around the ring grooves. There wasn't one booger on any of the ring pack area.
