Just got off the phone with the head engineer. The print will be finalized tomorrow!!! Soon I shall have pretty pretty solidworks pictures and then a shiny prototype in my hands.
Right now the nominal range will be anywhere between a 3.805" bore all the way to 4.025" (actually it's 2.500" to 5.500" but that's kinda out of our blocks limits
), 22cc inverted dome and a compression height that will place the piston anywhere you need it. Accumulator grooves and Gas distribution grooves will be standard.
I talked to the tech and I'm going to go ahead and spend the cheeze to make forced pin oiling standard. Horizontal gas ports will be optional but not standard.
The 22cc unit is a great compromise that will allow 9ish:1 static from a stock stroke 3.805 all the way to a stroked .060 4.1. What's really cool is these slugs will be able to achieve desired numbers without having to pay for boring, decking or spending a fortune on custom Cometic gaskets.
The ring pack gets rid of the old high drag 5/16 rings and uses either 1.5mm or 1/16 modern rings. (the choice comes down to the exact final bore size. There's certain bores that aren't offered in 1.5mm and certain bores that 1/16 can't fill)
With a set of what I'm building, a rebuild will go like this... First you measure the worst hole and figure out where it will clean up at. Rough hone it to size (no more boring!) and tell me the final bore size. Then, decide what static compression you want using cost effective non custom gaskets. That sets the compression height (no more decking!). As long as the piston isn't too close to the head, that's it!
With these slugs, the block doesn't lose any more meat than they have to, and the deck doesn't have to be thinned just to raise the compression. Plus you can use easy to seal $50 shelf gaskets instead of $100 Cometic gaskets that are pickier on surface finish.
The savings in machine shop costs and gasket costs will damn near pay for the pistons!
