Aug 24, 2012 #1 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 today i played with the BB 2Step while in Park. and this is what i got 12.5 *of KR, 9.6 PSI boost, 14.65 AFR. Attachments 8-24-2012 twostep.dat 8-24-2012 twostep.dat 242.1 KB · Views: 37
Aug 24, 2012 #2 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 2 Step settings 1-high limit 6000 Rpm 2-partial cut 250 Rpm Below 3-Low limit 3000 Rpm 4-8* timing retard Car was completely wormed up - Fan cycled. Alky was on with NO interruptions or reduced settings.
Aug 24, 2012 #3 K kidglok Balls Deep Joined Oct 10, 2010 Messages 2,278 your using the 6.1 chip? which wideband? and why the hell would you be playing in park?
Aug 24, 2012 #4 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 kidglok said: your using the 6.1 chip? which wideband? and why the hell would you be playing in park? Click to expand... 5.7 TTchip AEM equivalent
Aug 24, 2012 #5 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 Do you think that in gear it would make a difference?
Aug 25, 2012 #6 D DaRonne Edwards Member Joined Apr 9, 2012 Messages 80 kidglok said: your using the 6.1 chip? which wideband? and why the hell would you be playing in park? Click to expand... What he just said.
Aug 25, 2012 #7 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 OK no more in Park or N going to try it on Sunday night in Gear
Aug 25, 2012 #8 K kidglok Balls Deep Joined Oct 10, 2010 Messages 2,278 TURBOPOWERED68 said: OK no more in Park or N going to try it on Sunday night in Gear Click to expand...
Aug 29, 2012 #9 W wickedtt Active Member Joined Sep 14, 2003 Messages 1,169 Did you get any KR when your in drive?
Aug 29, 2012 #10 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 wickedtt said: Did you get any KR when your in drive? Click to expand... Still haven't tried it yet.
