SignUp Now!man, that seems low to me. my car doesnt drop below 20psi hot at idle and im consistantly at 60 psi at 60mph or higher. w mobil 1 10w30. 172k unopened miles
Someting does not sound right about that. I bet if you hooked up an oil pressure gauge you would be surprised at the results. I agree with the statement that you gauge is probably not functioning correctly.
Remember these cars were also the same cars that left the factory with lousy dirt filled paint jobs so every car will be slightly different. However oil pressures are usually within +/- 5psi from what I have been around.
Use a professional gauge (SnapOn, Cornwell etc) and check the OP. I bet your stock gauge is indeed wrong.
Weel today I bought valvoline vr1 20/50 what a difference in hot temp I ihad 23 psi and full throttle 60 all day long. I guess that's my choice for the summer and back to 10/40 winter thanks for the input guys:biggrin:
