SignUp Now!I'm guessing around 295ci
Raised cam version of the TA block?? Oddfire engine with a lot of stroke?? Please give us some details on how you'd get it there.
4.08 bore X 3.75 stroke. I would love to see a big ci odd fire setup. With the right software, you could even use a factory crank sensor for stealth mode
Yeah that does sound like a killer setup Cal! Kinda surprised nobody has built one yet. Maybe if I hit the lotto.:biggrin:
You think everyone tells the truth about what they have.....:biggrin:
sounds like a killer street setup to me
What size billet turbo would that ci support cal ?
Brick: I don't think you will be the first guy to build a 3.75" stroker
I have 4.030 bore x 3.750 stroke odd-fire motors. Rod to cam clearance on 2 , 4 ,& 6 is a bit of a problem but it can, and has been done. Looking back i would not have gone with the 3.750 stroke cranks because of the cam clearance problem. It is not feasable to run aluminum rods with that crank. I have 2 3.500 stroke cranks with some monster MGP rods that will be seeing service soon!! Mike
