SignUp Now!Quick6'n'-K.C. said:Wow, what a oldie.
Slow91z said:Wow this is old.
Blazer406 said:All I need is a 1.6X 60' time.... and I am there.
Blazer406 said:Well... didn't get there with the stock suspension... or the low boost I was running....
went a 1.81 on a 9-10# launch... 12-13 psi ... max boost ... except for some creep right before each shift..... 8.32 @ almost 80 mph ... stock turbo... stock intercooler... 12-13# boost....
The vigilante "0-Pump" 5 disk converter.... looks like it is stalling around 3600-3800 (per DS log) at 10 psi boost (with the stock turbo). I hope to put the TE61 on this week and the 60# injectors with the extender extreme chip.
Slow91z said:Why didn't you turn it up?
Quick6'n'-K.C. said:Honestly, i would get the meth kit on the car before you purchased or installed the bigger turbo, you wont make any more power unless you can turn up the boost.
BW
Quick6'n'-K.C. said:Launching at 12psi??? Not radials then right?
I asked if you were on radials and pump gas....
You have enough convertor for the bigger turbo, but will only be able to make some more power with it if you turn it up...
Eventually when you get the meth kit and that bigger turbo, you might add a small upgraded intercooler to help out with flow, the stock neck becomes a botleneck with the bigger turbo.
I would pull the stock lower intake and port match it to a felpro gasket, or wait till you blow a head gasket and clean up the heads and port the lower intake.
You do have a 3 inch downpipe right?
BW
Quick6'n'-K.C. said:Was this on radials and pump gas?
BW
