**What's Your Turbo???**
Whats Your Turbo????
  • Stock
    Votes: 19 10.7%
  • 44-60
    Votes: 56 31.5%
  • 61-63
    Votes: 29 16.3%
  • 66-67
    Votes: 33 18.5%
  • 70+
    Votes: 41 23.0%
  • Total voters
    178
  • Poll closed .
PT6776RHP with a .63 A/R PTE housing here.
No times yet with new turbo as it fried the tranny back in Nov.
My goals are low 11's and maintaining streetability. Which should be a no brainer with this combo, possibly faster if I want to push it.
We'll see.
Patrick
What turbo were you running before the switch??
Precision 6031RE, aka TE-60R, dual ball bearing TE-60 with a .63 A/R PTE turbine housing. Ran it to 27psi on the 11.72 pass at the GS Nats in 2007.
Patrick
Patrick
I guess we have similar tastes(with a little variation):biggrin: I had the TE60 on my car with the 12.02, ran at 24 psi. Switched to the PT6776S, and my trans also got toasted:redface: Guess we'll see what the 67's do with a stock motor!!
PT-70 P trim with .63 A/R. Old school. this turbo is probably about 10-12 years old but only has 1200 miles on it. The rest of the combo is this. Ported GN-1 heads,PTE FM, 224 .550 lift solid roller, 9:1 compression, custom 3 1/2 downpipe and TH-400 ATI 3800 stall and a GEN1 BS3 with 95s. I havent been able to go the track since putting it together. I just costs too much now. It is mainly a garage decoration right now. I'd love to go to a 70GTQ dual ball bearing but that is big money and it is hard to justify it when I dont even know what the car runs now. :redface: By all guesses and going off of what others have been capable of running it should go somelow 10s high 9s. maybe.
6152e, Stock Motor, Pats 32-3400 Lu
Got A 13.1 @16 Psi. Alky Next And Trying For 12.0 Or High 11's With More Boost. 11's Is The Goal And Then I'm Done.
Journal bearing TE61 w/ precision .63 exhaust housing, 3200 pro torque, ported heads/intake, and a comp 218/212 roller cam.
Precision 6131BB. 11.49 @ 118 on pump gas and M/T ET streets. Got kicked off the track on the 2nd pass. Didn't get a chance to "turn it up" ;)
I got my TE60 down to 11.07 before it self grenaded. I pushed a PT54 down to a 10.35.
Just a tiny PTE-44, signature is up to date including best ET. I'm not done with this turbo yet. Goal all along has been 11.50 street car, almost there...
No, I don't trailer it to the track, I drive it....
Chuck
Turbonetics GT-K 850 BB,I'm not too familiar with this. 850=85mm???
The GT-K is the the latest series from Turbonetics. Very nice looking turbos and designed with Map Enhancing Porting to stay in their maximum efficiency across a broad RPM range Their numbering refers to HP levels. The GT-K 850 uses a 72mm wheel. Mine is an S trim .85 AR. Below is a link to the GT-K
Turbonetics Inc. | Home | Products | GT-K | GT-K Turbocharger
Bryan
Look in sig. I built a new motor this year with ported irons, intake, roller cam. We will see how far I can push this little TE60 to. Hoping to dip into the high tens with it.:eek:
