Where does this go?
My guess is under the low planet in the bottom end. My book is outside if no one posts for sure I will grab it and look in the am.
Where did you find it.
It came in the alto rebuild kit. when i took 2004r bq unit apart this crap was not in there. atsg and it is vague. figure some one here will help me stop second guessing
please check for me, i hope this crap does not go low in there. The low part is all snapped in there allready. when i took the 2004r bq apart this was not in there.
It goes in the garbage in short. Not sure why they still put them in kits. It goes in the rear planetary below the sprag. It should always be updated to a roller bearing as your BQ will already have.
thanks
I hate to be s pain here but is there a picture somewhere showing the rollerized part, does it go under the gear that goes into the lo sprag? Just trying to be sure I allready snapped the lower portion of the trans in and do not want to go further till I'm sure. If I remember correctly the round gear that goes into the sprag with grooved side down did not have and needle bearing in there. It just sat in there.
You can see it under the sprag in this photo. This one has a plastic washer but you see where the bearing should go. You probably never had yours apart far enough to forget the bearing.
True I did not take it apart far enough. Bq trans so it may be updated thanks for the pick. I thought it went under the center gear with the groove side down
There was nothing inside this planet gear. The guy I paid to rebuild the trans must have forgot to put the roller bearing back in it. This is why I'm rebuilding the bq3 myself.
