My current set up on my 1987 gn is, i have a prescision ptb 6152 turbo, stock heads, stock location stretched intercooler,delphi 50lb injectors,walbro 255 pump, th 3inch down pipe, comp 980 valve springs, stock cam, 200r4 tranny,ptc 10 inch 3200 to 3400 converter, eric marshall turbo tweek chip set up for 110 race gas 26 degrees of timing 25lbs of boost, im using ac delco r42ts plugs, adjustable regulator fuel pressure set at 43psi with the line off and 40 with the line on at idle at wot my fuel pressure gauge reads 80 psi my mv on the scanmaster all the way through the quarter mile is 800 with 0 retard my timeslips of my pass is 12.31 @ 108, 60ft 1.78, 1/8 mile 7.82@ 87.82,what do i have wrong or is this all i can get out of this set up??????
