richardv6
- May 11, 2007
i have been having a noise that sounds like knock but cant ppt it.i removed intake and seen what looks like black combustion around bottom of ports of intake gasket (lower side).was not sure if it was intake leak or head gaskets leaking tords the intake gasket.so i removed heads and appeared ok.i had cometic gaskets and felpro blue intake gasket on it.so wondered if i should put another set of cometic gaskets or go with rjc setup.also do they make a thicker intake gasket for these anymore.also i have arp head bolts.
