Which SLIC works best??
i put gmbodyparts stretched slic on 23 row polished almm. . went from a fmic to this . could fell the diff. quicker off the dropped the temp. down 170 with the air on .the temp. of the air going to the motor stays around 100 115 deg. . the temp comeing out of the turboat 150 to 160 thats at 70 to 75 mph. when i would get on it the temp out of turbo would max out the scanmaster but temp. going in the motor would be about 190 befor the alky . big diff. in temp love the ic looks great and work better .:biggrin:
to see the real results on how well the i/c is working is too move the air temp sensor from the air intake tube to the plenum behind the throttle body.
gmbodyparts stretch & polished slic
I had air temp. senseor in the coupler befor the slic , and one in the up pipe to check temps.. to see the diff. of the air befor and after the ic. BIG diff.. I did put one behind plenum in the throttle body. the temp ran 110 to 115 befor the alky. I had a fm my in car it was running 190 to 210 all the time . Now withe slic i run 167 175 with the air :D
So the Precision SLIC is only availible in 3" inlet/outlet? I was gonna get one over the winter, but if they're only availible that way; I may have to go another route...:(
Yes, the intercooler itself only comes with a 3" in/out but you're given the option of TB size and turbo outlet size when you order. It comes with whatever size couplers, clamps and up-pipe you need.
I have purchased and installed many different aftermarket "bolt-on" parts on the cars I've owned over the years. Few, if any, have matched the qaulity of the PTE SLIC. I had mine installed in 2 hours without any problems. My only gripe is that I don't like the spring loaded style t-bolt clamps that it comes with. The lift in the middle when you tighten them. I may have over-tightened them though:redface:
My 24 row Mease SLIC was one of the best ones out there. Awesome to look at too ;)
Thanks for clearing that up. Ive been wanting one for a while now, but my bank account hasn't agreed to it yet...:eek: So that would work well with a TE-44 and a stock TB? I want something simple, reliable, and it has to work flawlessly.
The PTE is the way to go. Best SLIC out there.
Ive heard only good things about it.:cool:
Melissa's old set up for years was with a 44 turbo.. She used the old CAS V4 (was new when she started :rolleyes: ) .. Ran mid 11s all day and for years .. Then last year she ran the ol V4 down in the 9s with her new set up . Ill let ya know if we see anymore performance with the Precision one :p
I run the PTE SLIC on mine with a TA-49 and a stock TB. Works great and it's nice knowing if I want to upgrade to a bigger turbo later on I will still have enough intercooler to get the job done!:cool:
Posting with actual data.
I replaced my big-neck OE SLIC with a GN1 stretched SLIC (same one sold by TR Custom Parts). Here's a chart of intake manifold temperatures from two weeks ago at Putnam Park (light green) overlaid with this past weekend at NCM (dark green).
Despite it being ten degrees F warmer ambient at NCM than it was at Putnam, you can clearly see a huge delta in intake temperature, especially as speed increased. The chart is about a 50 dgree spread, and the delta between the two intercoolers is as much as forty degrees at the same speeds.
So, there's that. Stretched is better than stock.
