which turbo for my combo?
Kent86GN
210/215 comp roller,1.50 & 1.77 valves ported heads, roller rockers, 72lb injectors 62 mm tb matching plenum ,FMIC, XFI. I HAVE 6152E, TE64, STEALTH, 3200-3300 STALL.
Kent, with that combo, Id personally be trying the Stealth turbo. It may still be slightly small. I loved my Stealth turbo and used it on a very similar combo. It really depends on your choice. Most people here on the board think drag only applications but if your more into street fun, I like to use a smaller turbo and push it to it's max for a quick spool up. If your looking for a drag application, I feel that yu could utilize a larger turbo than any of the ones you listed. If you want to chat, give me a buzz brotha! ----Jeremy
I like the 64 as well but I think you have enough to step up to the Stealth!
Any one of them will get it done. The 6152 will spool the fastest but need a little more boost to run the number. The converter would be the only questionable part listed. You need a 5200 flash stall to get the most out of it.
