john keskes
- Dec 29, 2012
Guys, my goal is to keep the car as stock looking as possible with minimal $$$ dumped in. This is the combo i'm working with and a you tube clip of a quick run i did yesterday ( 78F temps ). Manually shifted at 4800 RPM.
It seems that it takes a while for spool up and hence it's not ripping the gums.
I want this car to spin it's wheels at will especially if I'm building boost off the line ! Motor has approx 6k on the rebuild. Idles great, No MAL codes. Don't know if has 100 lb valve springs.
Stock Long Block
Stock Turbo
Stock IC
Stock downpipe
Stock FP, not Hot wired
Stock Converter
245/60 BFG Radial T/A's
G80 posi
Mods:
37# delphi injectors
TT 5.7 93 street chip ( 20/18 deg, 16-18psi )
Gutted cat
Hooker 2 1/2 cat back
8" K&N behind front bumper
160 therm
-237 frp ( 43psi vac line off )
Scanmaster #'s during run shown : O2: 648 , 0.0 ret , BLM's 139 , TPS .42 / 4.24 WOT
I know , I know , i should throw the Walbro & Hot wire in ( it's still sitting in the package in the garage ) but you see from the vid i am pulling approx 58psi of fuel which should be fine for even 16psi of boost.
If I adjust the TT parameters to dump in more fuel and / or adv timing in first gear, will this get me a quicker spool ? Any suggestions I will listen!
Stock Long Block
Stock Turbo
Stock IC
Stock downpipe
Stock Converter
G80 posi
Mods:
Gutted cat
160 therm
