LookingforaGN
- Sep 26, 2008
I am a newer owner of a 87 GN have had it now about a year here are the specs on the car to what I have done and to what the person before me has done
Trying to get this thing into the mid to low 11's
Was only able to click off a 13.7 in the 1/4 with a 2.0-2.1 somthing 60ft
Please Help
Stock Block
Stock internals rod,crank ect.
Stock Turbo
Stock Trans, stock converter
Stock Rearend with 3.42s or whatever stock is
Stock injectors as to what I can see/tell
I belive a 206/206 cam
some 14" K&N Cone filter
TH 3" DP
3" Single Shot exhaust from Cottons
MSD wires
Boost was at 20psi from adjusting the rod on the wastgate
adjustable reg. at 45-48psi
Red armstong fuel pump with no hot wire (I know I need to do that)
Scanmaster 2.0 but not sure if I was getting any knock
I think I was
Mickey Tompson drag radials 255/60/15's on the rear
Thanks, Dan
Please Help
Stock Block
Stock Turbo
TH 3" DP
MSD wires
Thanks, Dan
