Basically what I am having problems with is where the wires join.
Do all the wires join together from the sensor to the plug that goes into the gauge?
2 are grounds, 1 is hot (12V switched) the brown is analog output and the yellow is digital, so leave out the brown in the whole equation?
Then if i do decide to go powerlogger, just splice into these and send the data to the powerlogger in the future?
The diagrams are there but they are a bit confusing. I'm a wiring n00b
ok, this is exactly how i wired mine up.
Do not install the sensor in the dowpipe or connect it to the harness. That will come later during calibration.
From the gauge harness:
Red wire to LPS on fuse panel
Black to ground.
Yellow to ground. (I found that the gauge lighting is no brighter than the scanmaster so i wasnt worried about the light dimming for night)
White to Brown wire on harness from LC1.
From the LC1 Harness:
Red to IGN on fuse panel.
Blue to Ground
White to Ground. (I attached the wires from the gauge to one ground wire and the wires from the LC1 harness to a second ground wire and ran both through the firewall grounding to the upper intake grounding stud near the throttle bracket.)
Brown to white gauge wire.
Yellow not connected.(This wire can be used to run to powerlogger if you get one.
Now the LED and the push button switch come into play.
Connect the red wire from the LED and one side of the switch (doesnt matter which) to the black of the LC1 harness.
Connect the black wire from the LED and the other side of the switch to the same ground wire as the others from the harness. (See
White to ground explanation above.)
At this point you should not have the sensor in your downpipe and it should not be hooked up to the harness.
The rest of this is directly from the instructions for calibration of the sensor.
Switch your ignition on and wait 20 seconds. During this time the LED will flash a 2 blink sequence repeatedly. After 20 seconds, turn the ignition off.
Now connect the sensor to the harness but do not install it in the downpipe. The sensor must be able to read clean air in order to calibrate.
Switch the ignition on again. The led will start blinking slowly and steadily indicating that it is warming up. It will then start to blink faster until it will finally stay lit with no blinking which means the sensor is heated up and ready to calibrate. Press and hold the button in for 30 seconds. During this time the light will go out. Once the button is released the LED will come back on. Now the sensor will calibrate itself with the clean air. After the sensor is done calibrating the LED will light up continuously. Calibration complete.
Now you can install the sensor in the downpipe and proceed with tuning.
I am currently working on an overboosting problem so I have not tried to tune with the gauge and I dont know what number I should be shooting for so maybe someone can weigh in on what the target number is that we should be looking for. You can see in my photo of the Wideband gauge that I installed the LED above the gauge and the calibration button to the left of the gauge. Everything fit there with plenty of room and its easy to see and access while calibrating.
HTH! Good luck with the install!
