When using the Wildwood master cylinder do you guys use the sleeve that goes into the master cylinder piston or do you leave it out. I used it but thinking I shouldn't have now. I have yet to bleed the brakes which should tell me real quick if the piston is being pressed at all by the hydroboost plunger. I have a feeling it is but we shall see tomorrow.
