cottonpicker14
- Feb 17, 2005
I cant understand why at WOT the max RPM it will go to before it shifts is 4300 or 4400.
I tried WOT also while in third gear only and the most it will go to is 4700 rpms. All the above with test pipe and cut out open.
It runs smooth as silk, no missing, no hesitation, no knock.
Alky with boosting to 21psi
O2 in the low 800's
FP 43 line off
BL at idle around 130
0 knock
Had the following work done recently.
Rebuilt tranny
new torque converter stall of 2800
new 100 lb valve springs
new bearings
new timing chain and gear
complete tune up
Mods that I did last year
Razors alky kit
RJC power plate
test pipe with cutout
160 thermostat
30 lb injectors
Walpro and hot wire
Any suggestions or ideas ?
Thank you
O2 in the low 800's
FP 43 line off
0 knock
Rebuilt tranny
new bearings
complete tune up
Razors alky kit
RJC power plate
160 thermostat
30 lb injectors
Walpro and hot wire
Thank you
