Paul Clark
- May 22, 2003
Took the car out for a little testing to see if I had improved the knock situation. It's better after replacing the vac. block gasket and sealing the nipple on it for vac. brakes. Zero knock at gradual accel. to 18 lbs.. Red lights on the gauge when flooring it in 1st, but 0 knock recorded on SM.
When I got home, at idle the 02s were mostly below 100 and the BLMs were at 115.
What does this mean and where should I look next?
Eric's alky chip.
Eric's alky chip.
 .. I've seen a few cars with the wiring harness laying on top of the knock sensor.. cuasing it to bang against it when the motor tq's over.
