11.60et @117 14psi
KDS looks alot bigger on video :biggrin:
Al are you still coming to the track rental? I am holding two spots for you!
Wow mid 11's on 14psi, must be nice.
Got any pics of that liquid intercooler??
Why do you still have the heavy and only 7" wide stock rims??
I bought a set of centerline convo pros 15x4, 15x10 5' backspacing, with a 275 50 bfg dragradial, and dont like them. I didnt take any pics of them on the car, but they stick out way too far and there is about 1 1/2" to the inside of clearence. I really need a 6 1/2 backspacing but they dont make them, and weld wheels hit the caliper :mad: Anybody have any suggestions. Thanks AL I will have some pics soon
PS going to make back to the track one day
Factory wheels are 5 inch back spacing. Maybe a 15x8 with a 5 inch back spacing.
The 4th gens have 5.5 back spacing.
Is the rear factory? Or factory width :confused:
Factory rear....Even with the factory rear wheel with a 255 tire there is over a inch clearence. I tryed a 15x9 with 5.5 that was about perfect, but the calipers hit the middle of the inner rim, about a 1/4". Is there any other calipers that I could use
Dont know if this can be done, a lot of the 4th gen guys will get a die grinder and grind some of the ribs of the caliper.
I'm contemplating going to different wheels and tires.. so I am in the same boat. My difference is I have the 9 inch rear.
See if I can get some 4th gen rear wheel to trial fit.
