Title says it all.... I have no idea what the deal is..
Here's my setup:
Hot wired warboro pump
4" front mount
Turbonetics Delta Gate and boost controller
T64E Turbo
3K stall
Unopened 109 block
Scanmaster
3" downpipe to split 2" exhaust
vacuum brake conversion
85mm maf
translator
TT chip (pump gas)
65lb injectors
Fbody radiator
Poston headers and poston crossover
With 10" slicks and c12 I ran a best of 14.86 at 20lbs of boost with 750 o2 count....My fastest trap speed was in the 90's
With this setup I'd imagine I'd be into the low 11's at least. I turned the boost down because I was experiencing sneeze at the top end so it's set to the chips recommendations of 16-18lbs.
Engine temp was 180F-190F and I experienced zero knock.
I have no idea whats going on. Any suggestions?
BTW: After this weekend this is what our local GTO owner made... I'm 1badgn...:frown:
Here's my setup:
4" front mount
T64E Turbo
3K stall
Unopened 109 block
Scanmaster
85mm maf
translator
TT chip (pump gas)
65lb injectors
Fbody radiator
![082c97c578c9b45ac2a4cbc5d76c1ec2.jpg](/proxy.php?image=http%3A%2F%2Fwww.maconracers.org%2Fimagehost%2Fpics%2F082c97c578c9b45ac2a4cbc5d76c1ec2.jpg&hash=ccf079a815427061559612a7b15e8a40)
