22lbChevelle
- Jan 14, 2005
In your first pic, the bracket holds (from left to right), MAP sensor, fuel pump relay, AC relay, and spark module. On the driver side fender, the three relays are all for the radiator fan.
Man I've always been leary of cutting the factory harness but I'm getting close to saying screw it. Can't wait to see what you can do with the wire mess![]()
Just make sure to solder and heat shrink everything David. I'd hate to see a bad wire cause you to blow the engine again.
i am trying to find more heat shrink stuff as i ran out.
i am hoping HomeDepot has some.
Cutting
wire brushing the wire
soldering
heat shrinking it.
IF i had the money i would be waiting for the brown truck with a new harness in it for me. This being broke ship sucks.
A light color will keep more heat in the engine. I prefer Chevy orange or Buick red. The orange makes it very easy to find leaks and is a more effeciant temp color for the engine.
Both pics look great. What did you do about the throttle shaft seals?
