1968 Chevelle With '87 GN engine
In your first pic, the bracket holds (from left to right), MAP sensor, fuel pump relay, AC relay, and spark module. On the driver side fender, the three relays are all for the radiator fan.
Man I've always been leary of cutting the factory harness but I'm getting close to saying screw it. Can't wait to see what you can do with the wire mess :cool:
I was also scared of touching it.
But
The horse him self told me that shortening it wouldn't cause any problems.
i am cutting one wire at a time that way theres no way to mix them up.
BTW
Those 11 wires took me TWO hours and a neck and back cramp to do.:mad::mad::mad:
Just make sure to solder and heat shrink everything David. I'd hate to see a bad wire cause you to blow the engine again.
i am trying to find more heat shrink stuff as i ran out.
i am hoping HomeDepot has some.
Cutting
wire brushing the wire
soldering
heat shrinking it.
IF i had the money i would be waiting for the brown truck with a new harness in it for me. This being broke ship sucks.
Cutting
soldering
heat shrinking it.
Try opening a business in the ecconomy David.:eek: That's what I'm trying to do.:biggrin:
i am doing this to eliminate that sloppy jumper that feeds the map sensor 5 volts and i am debating weather or not to keep the ground jumper (map sensor to body) or wire it to the a ground of the harness.????
i am also going to be adding grounded bolts as i HATE the sheet metal grounds on the body.
Also is there such a thing as TOO much ground?
I looked over some of my original stuff and found extra grounds everywhere.
There can never be to many grounds David. I'll be adding some welding cable to mine from the engine to the frame and body to make sure there's no issues.
Got some more work done today
Still not done with the wiring but check out what it looks like.
i almost quit at this point
But i finally finished the big section of the harness
i still want to clean up the section that goes to them sensors/relays
this is what it looked like
I also cleaned the block to get it ready for the Machine shop tomorrow
i removed another 6 wires from that same heater area
Some of which were left over from my DIY alky kit.
i also tied the map sensor to the PowerLogger via the sensors OE wires so no more jumpers feeding the 5 Volts to the map or from the map to the PL and Alky system.
I just hope it all works once the engine is back in the car.
I am also thinking about painting the engine Silver/Aluminum Color to help with finding leaks.
What is a Good engine paint paint that will last?.
A light color will keep more heat in the engine. I prefer Chevy orange or Buick red. The orange makes it very easy to find leaks and is a more effeciant temp color for the engine.
YUKKK
i hate that Chevy orange or reds on and engine, well unless it matches the body.
I'd rather keep it black if thats the case.
This could have been messing with my performance:confused:
Trying to send them out to get welded and ceramic coated.
if not that one then this one
got a few things done, but no engine yet
this is my old over-flow bottle
this is my new over-flow bottle and new chrome radiator hold-down
i got tired of the sheet metal ground so i put this one in its place.
Trying to improve the sounds so i made this
Good idea using wood on the speaker tray. I have a carpeted peice of wood that need some improvement.
Oh I hacked my wiring to pieces recently, check out the pics in my thread its pretty slick.
