CZ 2004R trans, fresh & ready to go. With all "the bells and whistles".
This is a reliable solid bottom 10/high 9 sec capable street/strip trans.
Billet drum, input shaft, OD planet and ring gear, fully rollerized gear train, front pump and output shaft, billet servo, and trans brake (stage right type, but quicker, and better releasing). This is a lock up trans.
The unit also has 550 and 400 boost valves, rev kit, Alto wide red band, billet anchor pin, and extra clutches throughout.
Shifts are medium at part throttle, firm a WOT. (not harsh)
This trans also has a Hughes deep cast aluminum pan with drain plug.
$2800 outright shipped to you (cont U.S.). Look around and compare prices, this is a great deal with the core and shipping included.
1 year warranty.
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer. Or Vendor service area.
Thank you very much...
Brian hipsibri@cs.com
This trans features:
Billet forward drum
Billet input shaft
Billet OD ring gear
Billet OD planet
Billet OD ring gear
Billet anchor pin
Transbrake
deep cast pan
Sonnax billet servo
Alto wide band
8 directs
5 forwards > clutch packs
3 clutch OD
Rollerized pump, output shaft, low roller, drum, center support
upgraded TCC switch
new pressure switches
higher pressure spring
rev kit
550 and 400 boosters
hardened stator support
resurfaced pump
all new bushings and bearings
This unit has all the billet parts besides output, and can be used with any converter combo. We can also change this over to a non locker if desired.
1 year warranty.
Billet forward drum
Billet input shaft
Billet OD ring gear
Billet OD planet
Billet OD ring gear
Billet anchor pin
Transbrake
deep cast pan
Sonnax billet servo
Alto wide band
8 directs
3 clutch OD
upgraded TCC switch
rev kit
resurfaced pump
