Does anyone use a grainger valve to control boost levels around 28-30 psi?
If so did you modify the spring or ?? to get this much boost?
I've added a spacer to compress the spring more and even tried stretching it a little but it still only goes up to around 24psi max.
I may have to find a stiffer spring if noone has a good method to try.
tia
kd
tia
kd
