3" High flow Cat
Fuelie600
This is a used "Vibrant Performance" 3" cat. Was installed on my truck for 5 days ( about 110-120 miles ). Measures 15" in length. I went with a completely different system. Paid $105, and am selling for $75 shipped. PayPal accepted.:wink: Brian
can this be used on the GN's??? i need one and i have a Terry houston DP
thanks
It depends. If you are running the stock type cat/exh oval flange, you would have to weld a flange to this cat, or remove the flange from your exh pipe. If you are concerned about a physical fit, just measure the length needed for your set up. This cat is 15" total length w/ 3" ID pipe. Material is Stainless. Brian
Fuelie.
I'll take it.
What is your PayPal addy?
Patrick
