SignUp Now!Ken- pls post pictures of your exhaust, if you get a chance.I have built the system with ONE cross flow muffler in the stock location (Ultra-Flow), and it workes great! ...
.....If you do it youself with mandrel U-bends, then it's not too bad, cost wise.....
Dennis HATES and I mean HATES the DRONE of these cars. His persistance overcame the DRONE! (His wallet hurts badly from all the exhaust systems he has tried.) I installed an ATR dual system, it droned too much, So, I installed a 3" muffler in the Cat position to try and help, it didn't. Then wrapped the ENTIRE exhaust system from turbo to tail pipe with thermal wrap. That didn't do much, either. So he ended up taking it to Sean (ESR RACING) and had him try just about every muffer known to man. Sean came up with the Ultra-Flow cross flow muffler. (after trying about five mufflers-I think) THAT solved the drone problem and Dennis is VERY happy with it.
I am going to build a boost activated exhaust cut-out. At a flip of a switch(to open a air pressure valve), the boost will open a dump. Not the same as a electric dump, in that it will run very quiet until it hits about 12-14 psi boost. I can run a REAL restrictive and quiet muffler(s) system and then have all the power I need under boost. It will be pretty simple to fabricate. I'll just use an adjustable wastegate actuator to open the dump valve. The dump will only open under boost, and will shut as soon as the throttle is let off. If a cop hears you, it will idle and rev quietly if they say they heard you. "But........HOW officer......listen for yourself........." If it is loud under boost, it will get people out of your way. "Loud pipes, save lives" The motto of the Harley croud.
I'm also interested in how you got that twin turbo set up in there.
With lots of busted knuckles. Actually I remembered seeing Duttweiler doing it years ago. I was standing at the passenger front fender with the hood open. After a beer or three, I grabbed a turbo of the shelf and held it in front of the stock turbo, and figured........"Hey here is the stock twin turbo GNX/FBI deal. It took me a LONG time to 'cipher it out. Lots of cutting/tacking/welding to get it all to fit good. After I proved the system worked, I modified a set of ATR headers and moved the wastegate up top. The original system used a modified stock header. I still have the original twin turbo header and down pipe that I built. (for sale) After going to the ATR header, it really didn't improve anything, except that it looks better. The complete system is a bolt on deal. I could remove it from my car and install it on another with only the need to drill two holes in the core support for the intercooler(s) mounts. I just wanted to build something different. I got real tired of seeing cookie cutter Buicks. I didn't set out to make the fastest. It's just kinda fun to pop the hood on the car and watch peoples' expressions.:biggrin:
Looks like I don't need to make a boost activated dump. Oh wait......I can make my own. (cheap bass-terd that I am)
I will also be installing a three muffler system on this car, as soon as I finish a few other projects.
