4" MAF sensor/ MAF pipe
If you have an original translator or translator plus you will ned to buy an update chip with the transfer function of the new sensor/pipe in it. If you buy a new one it will be installed already. If you have a Gen2 or Pro there is a free software update on our tech board. You get a choice of a 4" hose or a 3 to 4 adaptor to install on turbo, you will need a harness to connect for plug and play, the translator one for the original translator or plus, the sensor to Buick one for Gen 2 or Pro. If you call and place the order will be sure you get the right items but it is not too tough
Mike
Has everyone been using the 4" MAF Pipe with the stock plenum and NO spacer (or bigger plenum such as the PTE) but with a 3" Up Pipe (such as the PTE stock location IC or a front mount with 3" pipes) ??
Phil,
What plenum is that you have on the car ?
From your pics, it looks like the up-pipe is either located higher or angled upward (or both?) and can clear the 4-inch MAF Pipe.
Does the Up-pipe hit your hoodliner?
RJC intercooler. and Hemco plenum, and No it doesnt hit the headliner
I'd love to buy one if only I could see some results from the many that have been sold....
Looks real nice Phil! That thing is gotta rock!
Who's downpipe? Is that 3 1/2"?
thanks rick
its the SPX-7 "3.5" DP... going to the dyno as soon as it quits raining here in south texas to get it all lined out...
