SignUp Now!what do you think about chip tuning or do you run a stand alone ecu?
looking to build a 750hp GN but need some guidance on parts to use and parts to stay away from............
Go with a 400 Transmission. Unless you want to have the 200 freshened up from time to time......
ok thank you for all the imput! i think that i am still going to use the stock block, is there other ways to reinforce the lower end in the webbing? i just want to make sure i do it right the first time bc i dont want to spend all this money and then have to did it all over again.
the thing is i am not going to beat the shit out of it every day, the car has to much meaning to make it all out drag car, i just want big power and use it when i need itso i really just need some ideas on parts like what you have used!
Go with a 400 Transmission. Unless you want to have the 200 freshened up from time to time. I would not use a chip either. Go FAST XFI. I wouldn't depend on the stock ecu for that kind of power.
.....and you don't want overdrive anymore.........![]()
Probably want to stay away from a production block at 750 HP?
A forged rotating assembly is necessary, but the block is weak in the main web area, and will still crack even with a girdle and/or steel main caps.
Remember, you are taking the block to a power level 3 times more than its original output.![]()
