trashmechlv
- Dec 4, 2013
87 GN E85. Im listing for sale as I want to get something different but can only afford one toy at a time. Stock unopened eng besides Sealed Power VS-739r valve springs. 120lb inj, ATR stainless headers and downpipe, exh dump and single 3" out back. Walbro 430lph pump with hotwire kit. CAS V4 Dequick intercooler. Bison MFS 6465 turbo. Modded ecm, Powerlogger, SD2, Scanmaster. AEM Wideband. PTC 9.5 17 blade converter, B&M Megacooler. Front susp poly bushings. Spohn rear solid lower control arms, Hellwig rear swaybar, front swaybar removed but have. Vacuum brake conversion. Interior great shape, only small spot carpet worn at parking brake. Headliner replaced within last 3 years. Paint is shiny but has flaws, up close can see scratches, chips and dings. some areas have small cracks in paint. Solid rust free body. Been in Las Vegas since at least 93. Front bumber has a ding on end see pic. ALSO have a longblock to go with car. Fresh never started. Std 109 block, Comp 206/206 flat tappet cam, ARP head studs. Heads redone with valvejob, new springs. $13800 for everything. I have a TT 5.7 chip burned for car also so can remove SD2 and PL and wideband etc.. and retain fresh eng to work a deal.
I dont need to sell so no lowballers please. PM me for serious interest and let me know on here you sent pm. I cant be on here constantly so I will respond when Im able. Sorry for longwinded post. Located in Las Vegas NV.
