Yeah. At least my 60 foot wasn't 0.3. That's a fast truck you have there Scott. I have a vid of that run too.
I'll post it for you in the video section. May be a few days. Remind me if I seem to have forgotten.Wasn't exactly a .3 but it was was definitely much quicker than normal. Still reviewing the datalog and trying to figure out exactly what happened. If there is any way I could get that raw footage from you it would help out a bunch! I'd compensate you for it if need be. See you at Barona in a few months!
Scott Wile
No, they are sitting around 5k now I believ. But we blew my last Art car converter up 2 weeks ago. Its a bitch trying to get the 91.5 turbo tuned just right, but we are getting there. Its simply not effiecient, until 24-25#'s, then its a beast!Good to see someone else using nitrous too. It is the answer.
I was looking at your sig. With the nitrous assist, do you still need that much stall speed?
Don-
I one of your 9.2* runs last weekend. I was impressed with how you just stayed at idle until the 2nd amber, then spooled and launched in a heartbeat!
How high do you rev? It sounded like ~8-9k rpm from the stands?
Congrats on the new best!
Thanks Chris. Your project looks to be going nicely also.COngrats Don, glad to see things coming around for you. Very nice 60'
TA's block.Don, what block are you running?
DOn hows the convertor in that car?
Thats awful quick for the speed.
At 9.1 the car should be running way closer to 150
Id love to see the et/mph after a bigger turbo is used. Id bet there is about .5sec there with more wheel. Just use a bigger shot to get it going:biggrin: . It should pick up a lot over 6700 at 28 psi.I think the pure T76 is just at its limit, running out of breath.
You were right on with your assesment. After studying the datalogs, I found that the boost was declining with engine rpm. It would peak to 29-30 psi by around 5600 rpm and ramp down to 25-26 psi by shift point (7400). After the shift, boost would be back up and then trail off again to 25-26 psi at the upper end, crossing the finish line at 25-26 psi. That would explain the low mph. I think the pure T76 is just at its limit, running out of breath. Otto, why did you get rid of the 4580 so fast?
I sold it cause i sold the whole car and motor.
I wasnt completly impressed with it.
But maybe i was doing something wrong.
Precision had a 4508 that was a great peice(81.5mm)
At your stage I would order one of the 47-88s in the small T4 housing.
I think its the best thing out there for Stage 1 style heads.
