Narrowband sensors are completely worthless for tuning air/fuel ratios other than stoichiometric, thats about 14.7:1.
They work like a three position switch, in the middle you have 14.7, and under that it will spit almost any number beneath stoich (iirc .440) , and anything above 14.7 it will spit out almost any number above the stoich MV reading for that particular sensor
this is why widebands came into existence.
Narrow bands are highly affected by temperature and pressure, to make things worse they aren't even consistent if you hold those two constant. By just varying timing, or changing your exhaust, or increasing volumetric efficiency you'll get three different WOT mV readings from a narrow band O2 sensor even though your AF ratio may have held constant.
There is even a narrowband O2 sensor "saturation point" whereby you start to run too rich, the sensor will start reading lean.
I'm still surprised that anyone doing any serious tuning looks at narrow band sensors at all for anything other than part throttle attempts at getting 128/128 blm and int. Even then, you have to run open loop so the narrow band doesn't swing which is a built in closed loop algorithm to maximize cat converter efficiency.
