Dusty Bradford
- May 24, 2001
Mathematically, the jetting I'm using should net around 300 hp, mathematically.
No one is sure why the net is less than the mathematical result. I've seen some speculate that the mixture of nitrous and methanol is so cold that a fairly complete combustion of all the fuel is impossible. I actually tend to agree with this thinking. Alcohol makes best power when the incoming mixture is at around 160 degrees F. This seems to net the best vaporization of the methanol fuel. I think that's why most don't bother with intercoolers. They let the raised charge air temp bring the mixture to an optimum temp. Of course, with the boost levels that are more common these days, the charge air temp can get quite a bit higher than 160 degrees F. Even after being mixed with the alcohol. That's why some blown alky applications have to run mixtures into the high 2s:1 to cool the charge down. Get too far above that optimum charge temp and bad things begin to happen fast with methanol.
I still feel your probably injecting 300hp worth of fuel and nos. The meth does contain more oxygen so in theory, it should net even more power but the cool combustion temp and the excessively retarded timing knocks much of the hit down.
Looking over all this info and seeing how much timing your pulling out, I have to wonder if the a/f ratio is even reading correctly. You have to be putting a ton of unburned fuel into the exhaust system. I'd tend to believe the motor would be happier with a 100-150 shot and more timing. Your already retarded at least 8* at your base of 30* while on the brake. An engine at 99kpa will take 38* easily while getting on the t-brake. Considering your engine is short stroke, it will take even more timing than an engine with a long stroke. Just looking over all of this. It would seem the engine with the proper amount of timing would need much less meth and nos to achieve the same result.
