Look guys. I'm not building a TSM, TSO, ATM or any other class car where I'm dictated to on how to build my car. I will also not be pressured by any one person on how I should build my car.
Tony. Was I in your ear when you had that large turbo and tight torque converter "TELLING" you how wrong you were? Nitrous sure would have helped you out, by the way.
The whole purpose of building this car was to go where no one else has gone. It certainly wasn't the plan to build another cookie cutter car.
Am I going to run into walls along the way? Of course I am. I'm not asking anyone out there to keep me from running into those walls, am I?
I've learned quite a bit from this journey, and I plan to learn just as much more. I'm even taking the time to write this all down for others to enjoy. If this thread is frustrating for you, then don't read it. It's that simple.
I do appreciate the constructive feedback I get from most of you, but remember one very important thing, I will decide what goes into my car, and at the time I decide.
Don't think for a moment that I didn't have a clue that the t/c was too tight with this new turbo combination. I had my reasons for experimenting with this turbo and converter combination as long as I did. It's called, learning all you can. Now that I feel there's no more to learn from this combination, it's time to move on. I find it amazing that someone would ridicule me for using a large turbo and tight t/c when they themselves did it too. And even worse, without the help of nitrous.
Again, I will explain the main goal of this project. It is to build a turbocharged stage I Buick V6 using methanol and nitrous to help spool the turbo. The plan is to have a car that I can idle into staging and bring to launch readiness within 1 second or less.
The fact that nitrous is in the mix, and it's in the mix to stay, means that the converter and turbo will most likely be different than the cookie cutter variety.
Those of you that have gone the cookie cutter route and have had success, I applaud you. I'm sure it was a long haul for most of you. There are plenty of people that are interested in your combination so that they can fast track their way to where you are now. Go share your combination with them. Respectfully, I'm not interested. I choose to make and travel my own path.
The challenge is what I enjoy the most about this journey.
