Razor's kit, 5857 turbo, 60's, TT chip , 25 lbs of boost. I year old pump and hotwire, both Racetronic. I added 8% more fuel all gears WOT. I have my turn on down to 4LBs and the initial at factory setting. At 78mph my boost is all in and I have 760 o2's and 6* of knock. Should i turn the turn on back to factory and bump up the initial instead of the other way? Gain knob at 7 or 8 made no differance. 3300 ft above sea level, 91 octane. Runs good at 20 to 22 lbs of boost. Scanmaster readings at idle.
af-09
LB-53
bat-13
int-128
bl-132
mph-0
temp-184
ats-190
rpm-850
tps-.42
iac-23
cc-18-235
no codes
af-09
LB-53
bat-13
int-128
bl-132
mph-0
temp-184
ats-190
rpm-850
tps-.42
iac-23
cc-18-235
no codes
