That's a good question.
What does that T with the TE45A run?
I know you guys understand that he always lets us know when the new stuff hits the market. If he leaks info, it could cost him his job! Give them a break, they could just stop making the Buick housing and make us switch to 4 bolt housings, external gates, and v band downpipes. So if you look at it that way, the $550 upgrade is Cheap if you "think" you will "need" the CEA turbine.
I'm not sure my question was understood.
My "old tech' turbo was purchased by my builder in mid/late August, just a month prior to the realease of the new technology.
I paid top dollar for it.
So, do the new turbos cost as much as a recently purchased "old tech" turbo with the $550 upgrade installed?
If so, that's fine.
If not, I call BS.
How is that logic wrong?
My builder and I have talked about this situation and have come to an agreement as to whether or not our goals for the build were met.
I'm not unhappy with the results at all, however, early in this thread I asked to be told of information as it became available. I thought I was pretty decent about it.
The posts in this thread indicate that many were PM'd with possible remedies. I'm not one of those people.
I only know what I've read here because, well, I don't really know why that is.
I do find it somewhat disappointing though.
That's my 2 cents. I've said my piece and I'm done with all of this now.
I'll live with what I have because my car still kicks f**ing ass anyhow!
"Specifically engineered to produce massive power gains over older turbine wheel designs, usage of Precision’s new CEA wheels typically results in an average increase of 30‐45 horsepower over comparably sized standard designs."
The comp wheel is still the same CEA as before, you guys are only missing out on the new exhaust wheel. What's hard to believe is that the GN community could gain 30-45hp on just an exhaust wheel, this is why I asked earlier about the wheels. I'd imagine you guys are only missing out on 20hp if it was 65 vs 66 exhaust wheel. See what PTE says concerning our platform and the new wheels for true hp gains. Not worth getting worked up over it though, you can't buy something until it's released.
I'm thinking those old wheels would go .5 faster than you posted. Gn4u2c has been mid 10' on an unopened with the 6262. With higher CR and everything else working together it can probably support 9 sec passes. The 6765 will go at least a .70 if not a .60 in the right hands. I've gone from a 60-1 to a 76hpq on my blue car and gained nothing and that's at 500whp. Anyone who bitches is silly unless you are running the balls off what you have. Anyone who wants me to back to back a pair of them I have the 500+whp engine in my blue car and the 700+whp engine in my black car. Send in your turbos. I'll run the same a/f and timing and get very close boost curves across at least a 1000 rpm span. There will be no bias.$550 is for the parts and labor to replace your "old technology" turbine wheel and exhaust housing.
I may have missed it but has any 231-235ci engine maxed out one of these units yet? Has anyone ran these times?
Has anyone been faster that 10.50 with an "old" 6262?
Has anyone been 10.20s with a 6265?
Has anyone been in the 9's with a 6765?
None of that shoulda woulda coulda crap either! Has it been done?
There's a lot more than that holding them back. Look at the sigs.I've tried to get a comprehensive list of times the new billet turbos are running in this thread. http://www.turbobuick.com/forums/time-slip-combo-database/296769-times-combos-billet-turbos.html
There are many varying results, some impressive some no better than an old school. I'm pretty sure there are more times out there that people haven't reported. Kind of wish they would so more combinations could be seen and analized. It seems like one thing that holds some times back is the psi that people are running.
Guys have been in the 10's with a ta49. I highly doubt this magic wheel will be an instant 40hp.
I understand from Patrick someone with a non-buick setup was running a 6765 setup had one and made some baseline runs at a certain boost (maybe 25 psi.... can't remember exactly)...... they shut it down..... swapped to the 6766 (only difference being the exhaust wheel) and at the same boost level.... it picked up 65 HP.... and spooled up like 200 RPM sooner.
That is not an apples-to-apples comparison I admit.... but it sure does sound like they have done a fine job with the new wheel design. I'm sure the buick 3-bolt design is beginning to choke the turbo down some at this power level......and hence one of the reasons I say it isn't apples-to-apples.
