TURBOPOWERED68
David
- Jan 31, 2006
@#%#$^ always happens to me.
I was going to install the new injectors, chip and valve springs. Then I find the main pulley/damper loose real loose I mean I unscrew the bolt with my finger tips loose,
so at this point I abort the upgrades and go to work on the damper.
I just pulled the one of the regal and dropped it in.
To add insult to injury my almost brand new $150.00 S*K torque ratchet goes completely out of wack the handle comes loose and all most falls off. So go to my trusty impact gun with a little well a lot of medium (blue) lock-tight.
How often do these POS get loose?
And do you think the Impact gun with Medium lock-tight is tight enough?
Next problem
The rockers seam to have a lot of play, are the rockers soppose to have up and down play (about 1/8 inch)?
Or are they suppose to be snug?
Next problem
