I also want to throw is out there, because it's has me thinking quite a bit. When Pat and I were cleaning up the intake from his porting work, we took a water nozzle and placed in it the intake/turbo hole of the manifold. Water was gushing out of the 1 & 2 ports, some coming out of 3 & 4 and very little out of 5 & 6.
I hadn't finished reading the porting book that I bought (it's now in the hands of either Pat or Richard), but it mentions air flows like a liquid. If that's the case then it seems ports 1 & 2 would get the lions share of air and 5 & 6 would be deprived. I didn't mention this while we were working on the intake and putting it back on my car, because I really wanted to have my car back on the road the same day. Also it really didn't make a difference since that's the intake I was running with before I brought the car in and wasn't going to be much different from whatever intake I left with.
So air distribution is on my mind quite a bit at this point.
Eric
One thing you need to think about is about Volume. When we were cleaning the intake with the water hose. We were not able to flow the volume of water that the flow bench could flow in air.
Also when that water was just trickling out of the ports it was on the floor of the ports. In airflow in the ports of the intake and cylinder heads most of the air actually flows more in the roof area VS the floor. This is the reason for more modern intakes and heads using the catherdral ports.
