I was thinking of ordering a cam kit from Full Throttle and was wondering if anyone has had any problems with the cams, lifters, etc or installing them. This is going to be the second time for a cam swap. Flatten old one in less then a 1000 MILES. Im open for suggestions on which cam I should go with to. TE44, Dutt neck stock IC, 60 lbs, TT, 3" DP, large valve heads and mild port. I"m going to buy a Torque Converter as well at the same time. So I need direction for that too. I drive mostly on the street with some track time. Any help would be great. Thanks.
