it wasnt the pcv....blocked off or unrestricted, running breathers on each vc
it wasnt the intake valve guides....had them changed
it wasnt the turbo....no oil in dp or exhaust side, also tried a different one that was new
it wasnt the intake....took it off, used sealant around the valley pan gasket, and on the heads
it must not be the rings....doesnt happen at boost, only at idle once the car warms up, and compression is 160's
it must not be getting into the combustion chamber....all the plugs are clean
its a fresh rebuild, about 1500 miles. Same champion irons that were on the old build, and it didnt smoke then. i searched and searched and searched and did not seem to a thread that pointed to something other than what i have checked so far. Its definitely blue smoke and smells like oil. It does not smoke while warming up, only when it idles for a bit after it comes up to temp. The only thing i was thinking was maybe the exhaust valve seals? but i dont think the champions use them?
where the heck could it be coming from????
