SignUp Now!I will post as soon as I get some track times. I also went to a PTE SLIC so it won't be exactly apples to apples.You should start a thread just on the comparison of the 44 to the 58/58, I bet a lot of would be intersted
Sent from my XT1650 using Tapatalk
Be cool to get your driving impressions...feel so to speakI will post as soon as I get some track times. I also went to a PTE SLIC so it won't be exactly apples to apples.
This weekend I was installing a stock ported Champion lower intake on a customer of mines car that has a single nozzle alky kit from Julio. My question to Bison, would there be any possible way that these small holes could get plugged up? Reason I am asking is because the inside of the intake and dog house I was changing out was so gummed up from (I'm assuming) the PCV system?? Could that potentially create a issue down the road? or is the alky strong enough to keep the holes clean? And last question is, what do you recommend if anything for cars that have this similar issue with gummed up intakes and dog houses?
I told him about your system and I think he purchased it from you this weekend, so hopefully I will be installing this on his car in the weeks to come.
I would think that Alcohol, being a great solvent, especially of oil and petroleum products, you wouldn't have any type of issues getting clogged especially spraying high pressure. But am still curious what Brian has to say.
Sent from my iPhone using Tapatalk Pro
The meth would keep things clean IMO.That's my thinking as well... But seeing as how this system is not on 24/7 (on daily drivers) and just comes on occasionally with 2 to 3 sec stints on the street in most cases that would be my only question (not concern). I drive my car more then I beat the pants off of it, and more times I go to cruises a hour and change away from home and never get into boost each way. So my curiosity is based more from a driving stand point then a all out race application.
I have two people wanting me to install them and they have the BGC/Champ intake and are out of luck. Bison says he has no plans to as of yet.Is there any of these for a Champion Race intake?
To his point, will the meth be able to keep it clean if it's not used often?The meth would keep things clean IMO.
Shouldnt be on there if its not boosted often. Just have stock boost levelsTo his point, will the meth be able to keep it clean if it's not used often? Sent from my XT1650 using Tapatalk
Ahhh, but if you need/want to boost it up, then what? I think the plate is awesome, just conversing about any possible issueShouldnt be on there if its not boosted often. Just have stock boost levels
They could be plugged if a filter wasn't used. I'd always use a pre-filter on anything that was a motor fuel or anti detonant. As far as gumming it up I doubt it. The pressures involved in a properly working system (sometimes over 200psi) would likely blow out anything that might land on one of the holes. You'd probably have a better chance of blow back hitting the end of the fuel injector and causing a problem though this rarely happens unless the engine is put under power with an intake valve barely hanging open
I wonder if Anyone is using this setup? It seems like it would work?
View attachment 308276 With the turbo, intercooler, and Bison's alky plate, new best. Getting the launch down is tough, running 255/60s, and air bags.
That looks like a good run to me without knowing the combo.
