ATI dampner internal balancer
vboosted6
I'm currently building a stroker motor that's internally balance.I know I can't used the stock one because its an externally balancer.I've use ATI products in the past and been very happy with them.Can the ATI damper be my modified to work.
It's not worth the effort to make it to work. BHJ makes a nice damper which is neutral balanced and configures with the stock pulley, crank sensor etc. Also TA sells a more affordable version which is similar to the stock one except neutral balanced and made from steel. Both the BHJ and TA balancers are SFI approved too.
Neal
I just check the link but it doesn't mention if it has provisions to accept the reluctor wheel.
I will try to get a pic of one installed today if y'all want.
Sent from my XT1585 using Tapatalk
Not that it matters to most, but does it have an SFI rating?
I didn't see it on the listing.
I bumped the image up, and see it has the SFI logo on the face.
Not sure what HP level this will be used on, but the ATI on my LS has a 800HP warning issued...o_O
This is great , nice to see the aftermarket thinking of a 30 year old hot rod!:cool:
Did Chris use one on your engine? We decided to switch from the BHJ to the ATI on my engine since the BHJ needs to be repaired.
One on his. Have one ordered for mine
