Phoneguy
Cometic HG stress tester
- Aug 27, 2002
SignUp Now!How lean did it go? Was there a system that let you down? Alky or fuel?
I thought I had bad luck...
What do you consider a safe tune?
How much boost have you ran(tuned for)?
EDIT: 9.6:1 30psi... That is some serious pressure on the engine for pump gas and alky...
I can see why the damage was done. Sorry... I had the urge to build a higher compression engine and run pump and alky but too many more experienced guys advised me not to.
I guess the head can be welded at Champion ?
Wow sorry to see that.
What would be the cause of the boost spike?
