Yes they are installed on the positive connection point. They are capacitors used to filter out certain frequencies. You have to make sure you use the correct one for the correct range for whatever speakers or tweeters you are using. It's kinda old school though. You can get an active or passive crossover for really really cheap but they do work if that is the route you want to go.
