MNcarbturbo
What's Fuel Injection?
- Mar 9, 2009
With all the talk of H bodies I want to get one to put my supercharged 3800 in. Now that would be fun! 400ftlbs in a small package and hardly any weight.
SignUp Now!It's not needed if you've got the heater hooked up and all it does is put more heat back into the engine. When I eliminated it on the Skyhawk it dropped the coolant temp 20 degrees in summer weather but didn't effect the heater in the cold times at all.Btw, why did you eliminate the bypass?
It's not needed if you've got the heater hooked up and all it does is put more heat back into the engine. When I eliminated it on the Skyhawk it dropped the coolant temp 20 degrees in summer weather but didn't effect the heater in the cold times at all.![]()
One of 3 ways Freddie. Use a pipe tap and plug it, weld over it, or use a rubber cap held in place with a hose clamp. I prefer the pipe plug but I also put a cap on top of that just as a precaution.How did you cap the port on the back off the water pump that feeds the bypass?
i need a picture of a 83 ttype thermostat housing.
does anyone know where i can get one from?
I think I might have what your looking for. Let me check my parts bin, and I still have that housing for the filter. Ill check!
that's the way it always is. you see it one day the next day you cannot find it. today, i spent 2 hours to find a face shield for grinding. lets just hope this bad weather passesCan't seem to find t state housing I only seem to see it in garage when not looking for it.
