Hot Air Beast
Hot Air Lover
- Mar 10, 2007
I don't usually recommend any products but this one is so great compared to some others; like the Red Devil River product, that I just have to post something to help out all 84-85 GN owners ( works for 86-87 as well but I have no comparison data).
The product is the ALDL BT adapter from 1320 Electronics LLC, owner John Wales (Florida).
The 84-85 has two data messages, one 8 byte and one 20 byte. Using the 8 byte the data stream is three time faster than the 86-87 which has one 28 byte message. Comes with a free app, the proper 1Dadx file and dip switch settings. ALDL Droid for example, costs money.
There is no requirement for the 10k resister across the aldl pins like Red Devil River's adapter.
I had bought the Red Devil River product and could not get it to work - support from Timm Bacher was virtually non-existent and he would not refund my money.
The 1320 product was easy to install and works great. It was so, so easy to adjust the TPS with a readout on my tablet to look at rather than trying to hole the leads on my digital voltmeter at the same time as moving the tps and watching the needle - need six hands.
You can customize the readout on the tablet to show digital, dial, bar graph, whatever.
Here is a list of what I get (and I am still learning):
Vehicle Speed
Engine Speed
BLM
4th gear indictaor
In gear indicator
MAF
Vaccum at EGR
O2
Rich/Lean transitions
IAC
TPS
Coolant temp
Knock Sensor
Error codes
I have used it to diagnose a stuck open thermostat which was causing a rough idles (was 165 degrees rather than the 190 the ECM wants to see. I have also used it to adjust IAC and TPS - readouts so easy to see on the tablet.
I couldn't recommend John Wales enough - just great dealing with him as opposed to Timm Bacher.
Just saying - this was my personal experience and I love mounting my Samsung tablet on the dash and watching the numbers as I drive.
YEA - no more looking for a "Red Brick".
Vehicle Speed
Engine Speed
BLM
4th gear indictaor
In gear indicator
MAF
Vaccum at EGR
O2
IAC
TPS
Coolant temp
Knock Sensor
Error codes
